Brief Description: Riveting backing plates and nut-plates to rudder s
Squeezer made an easy job of those mostly. Seems that when the rivets get longer than about 3-6, then sometimes don't squeeze as easily with the squeezer. I used the normal riveter in these cases and the bucking bar. I know I could increase the air pressure to about 100 psi, but always worry that I would forget to set it back when I swtich tools.
