Brief Description: Enlarging the HS405/404 and spar holes.
This was a simple step. Simply swap the bit with the larger #30 drill bit and make the holes in the spar and rib flange bigger. Again, the #40 in the 12" size does this nicely to make the holes bigger for the rivet.
