Brief Description: First attempt to leak test Right wing tank
I had purchased from Vans Aircraft the leak test fittings. I installed the test fittings and followed the instructions to pressure up and leak test. All went well, except the balloon would leak at the fitting. Still had plenty of air to check for leaks on the exterior with soapy water. All areas were sound, no leaks except at the balloon. Will correct and try again tomorrow.
