Finished installing the end ribs on right wing tank. Along with the build, I plan on eventually installing wing tip tanks from Hotel whiskey aviation. I purchased the fuel bungs for installation during the tank build. Picture one shows the fuel bung installed on the outermost rib that will be next to the leading edge skin rib. I have added an opening on the right leading edge skin for access to this connection later.Picture 2 shows the vent line fitting installed on the fuel sender end rib. Pict 3 is of the fuel cap installed, On the other side of the fuel cap is the loop bracket to hold the vent tube to the highest point in the tank
Fuel bung installed for later tip tanks
End rib installed with fuselage bracket and vent fitting
