Brief Description: Clecoed the top and bottom wing skins on the wing
After checking for twist, I clecoed the top adn bottom skins on the wing frames. Next is to make wing walk doublers, then match drill all skins to ribs and spars. I, as per plans removed the cover from the wing walk doublers and measured to cut to length. No big deal at this point, measure, draw a line, cut, deburr, install under inboard top skins. Next match drill all holes.
