Brief Description: Setting up Wing jig with spars and ribs checking f
After installing the ribs and rear spar to main spar, I set units in wing jig to check for straightness. I used as per plans , plumb bobs from the main spar on both ends. Measured the distance from the rear spar to the string. Both were equal in distance. 2 7/16". No twist, on to the next process
