Brief Description: Rear seat back bulkhead storage bracket gussets
I fabricated some steel plates and welded 3/8" nuts for the tie down rings holder gussets that mount behind the rear seat back Bulkhead. I used 1/8" steel plate for the anchor bracket. Drilled a little over 3/8" holes, then Mig welded the nuts to the plates. Primed and installed with an470-4 rivets.
