Alodined the parking brake bracket and the mounting plate. Installed the monting bracket only 1/4" lower than the original bracket that was removed. This bracket is located in the center of the pedal assembly just below the panel on the rear bulkhead of the front baggage compartment. Picture 2 is of the final assembly of the parking brake along with the brake lines bent along the bulkhead and inserted down into the gear towers to the brake fittings. Brake line assembly complete. Will wait to install the pedal assembly till I get the forward skin and bagage compartment installed. Have to lie underneath the panel to rivet the baggage door.
