Brief Description: Final fuel line installation in Fuselage
Layed out the bends on the same type of wire and transfered to the measured fuel line. Hardest line was the line across the front of the wing spar section. With a little time, it was bent and installed up to the fuel selector valve. The left tank was a very short piece from the selector out 4"on the left side. Same as the right side for later attachment to the fuel tanks. I tried to just make an S bend for the pump to firewall tube. The bend was right on, just too short for the flaring tool and had to go a different route. Ended up with a loop type attachment tube for the firewall as in picture 3. Fuel lines in the fuselage are complete. Nex, on t to the brake system.
Right fuel line across the wing spar
Closer look at the filter and fuel lines
Loop in tube to accomodate the firewall to pump line
