Brief Description: Fuel pump installation with fuel filter
Prepped the fuel pump and filter mounting brackets, as per normal procedure. Deburr, alumi-prep, alodine. Installed the Fuel pump bracket and the rubber insulator mounts in the front of the fuselage as shown in the first picture. The Pump is attached to the bracket via a standard hose clamp. 2nd picture is the filter bracket installed along with the Andair fuel selector valve. 3rd is of the filter installed along with the first fuel line installed from Valve supply to filter. I then the fuel line thru the gear tower to the fuel pump. First bend, and flare for all Fuel tubing. Went together really quick.
