Tims Web Site
Date: 3-26-2016
Number of Hours: 3.50
Brief Description: Applied Polyurethane primer to fuselage interior
Finished the prep work, scotch brite all surface areas inside fuselage, pre washed again, tack cloth all areas to be painted. For the interior, I did not install paint booth walls. I had a good air movement across the fuselage from the filter rack. Manufacturers suggestion to mix paint or shake for 15 minutes. As I stated in a previous post, I was getting a pneumatic paint shaker from HF. I stated to bolt to a stable table. I clamped in place on a stable table for test, all worked really well. I couldn't see hard mounting the shaker since clamping in place worked great. Shook the paint for 15 minutes, ixed the stated parts of paint, hardner, reducer, then let set for additional 15 minutes. Spraying the paint only took about 30 minutes, the rest of the time was used setting up.
Finished prewash/tacking cloth
Tack coat/full cross coat follows
Nice shine on primer
