Received the Garmin servo pitch brackets and decided to install while fuselage is still accessable. As per instructions, removed small amount of bulkhead to allow for flush fit to bell crank brackets. Drew a line along the center of the brackets for drilling location. Marked for 5 rivets. drilled, deburred, scotch brite, alumi-prep, alodined. Clecoed in place and installed final rivets
