Brief Description: Alieron trim servo brackets/ battery tray
Gathered all parts for the rear battery tray assembly. Match drilled, deburred all holes and edges, scotch brite all parts, Did the same for the RV-8 Aileron roll servo brackets thru the alodine process.Finished the fabrication of the pushrod for the roll servo attachment for the springs and servo attachment holes an slot required. Will install brackets now.
