Brief Description: Final adjustment of Elevator travel. ( no pics)
Time to finish the partially adjusted elevator limits. I checked again the travel of the elevators. 26.5 degrees down an 22.5 degrees up. My goal is to have the travel ( which is to lower the tail) to as close to 30 degrees as possible without the control horn hitting the back of the rear aft plate. Conclusion. I made necessary small removal of elevator stop till I have 29.6 degrees of up travel ( which will lower the tail an raise the nose). I chose to keep the down travel as stated 26.5 degrees.
