Temporarily installed the rudder cables from Rudder to front pedal assembly. Drilled the 1/4" holes thru the fuselage for cable attachment locations. Installed the rear seat pedal assemblies an associated hardware. I had to remove 1 bolt from the landing gear weldment to allow the rear seat pedal assembly pivot point mounting bracket to be installed. This was another place where the right angle drill came in handy. Drillled and attached the pivot point hardware for rear seat pedal pushrod and cable attachment. Attached Rudder cables to pivot point along with foot pedal cable, could then proceed to get the proper amount of adjusting washers on the front of firewall for Rudder cables.
