Brief Description: Page 344 Completing the Throttle Connection
September 10 2013
Last night I made the L-Bracket that holds the outer cable still while the inner cable slides in and out. When I tried the throttle however, their was some flex in the aluminum bar stock I used. I tried a thicker aluminum, but when I bent it to make the L, It broke at the bend. I decided to just make a 2nd L-Bracket and Lever piece and double each and it did the job of stiffening the assembly.
2 pieces put together
The assembly under the seat
The L-Bracket holds the outer cable still is riveted to the Center Tube between the seats
