Brief Description: Page 345 Making Panels, Right Wing & Right Main
September 11 2013
A full day of no Plumbing jobs had me working on the Panels all day and into the night.
I drilled the hole for the 12 volt power outlet and cut the opening for the ELT on the Right Wing Panel only to find a screw not screwed in enough on the table had scratched up the panel. I filled the scratched with body putty and sanded smooth. I covered it with the Steel Look vinyl and installed the power outlet and ELT.
I cut the hole for the clock on the Right Main Panel and covered it with the Steel Look vinyl and installed the clock and the LSX letters.
