When I removed the Turtle Deck, I found that the back lip of the Hull that I had to cut down to get the Turtle Deck to sit right, had not reached the holes I drilled in the Deck on the right side. I used a piece of the cutout for the back window to add some height and fiberglass it in. I clamped it to hold it up till it setup and drilled the hole that missed the Hull.
