Brief Description: Battery tie down and 12v socket
Dan and Justin prepare the battery for use. They added the acid and mounted it on the gryo. They cut the threaded rods to length and added rubber to the hold down bar.
I soldered additional wire to the 12v socket leads to ensure they could reach to wherever the termination will be which enabled me to install the instrument support on to the keel.
Add adel clamps to the rudder cable at the support for the instrument panel pod.
