Steves Web Site
Date:  10-3-2009
Number of Hours:  8.00
Brief Description:  Paint Pod and support
I touched up the bondo I had placed on the instrument panel and sprayed black paint on the lip of the face where the instruction face plate will be.
I found the 12v spocket and drilled a 1" hole for it in the instrument panel support. Then I need to drill through the structure for the wires. Doing so, the flexible shaft with the grinding wheel got stuck passing through the 1" hole, it became a 1.1" hole.
Painted the instrument panel and support and touched up other areas on the keel.
Pod support with 12v socket hole
Sanded pod with bond repairs
