I spent most of my time trying to figure out the Engine Wiring. The instruction manual does not tell where the cable bundle enters the cabin or how it is routed to avoid interferring with the control rods.
Began to work on a bracket for the landing light. I had 2"x 1/4" stock. I layed out the Harbor Freight driving lights and cut the stock to 8". I needed "L" brackets for the lights to bolt to, so I cut some scrap 2"x2" square stock on the opposite corners to make the brackets.
I will need two MS1919-WD26 clamps to hold it to the nose gear if I don't use a muffler style clamp.
I secured the heater water hoses using wire ties to the nose gear support and the high pressure fuel hose.
