Sonnys CH650
Date:  4-29-2012
Number of Hours:  3.10
Manual Reference:  Dwg 6W2
Brief Description:  Trimmed & Drilled Aileron Skin
Layed out rivet lines, marked rivet locations, center punched and drilled to 3/32".
Udate from 10/10/13: Noted that a couple of dimensional derivations are necessary:
1) The vertical rivet center lines on the front web. The actual distances to these lines is NOT the same as the dimensions shown on the drawing to the center lines of the top of the ribs. Because of the 87 degree angle of the ribs it is necessary to measure the distances from the edge of the skin to the points where the rib top center lines intersect the line defining the face of the front web. Transfer these dimension to the web to ensure one consistent centerline all the way around each rib.
2) The bottom cutout is shown as 94mm from the plane where angled cut on the top skin intersects with the top of the front web. Measured this distance to be 10mm from the edge of the un-cut skin so the actual pre-cut distance to the bottom cuttout (at the bottom of the front web) is 104mm from the untrimmed skin edge.
The 87 degree rib angles must be taken into consideration when locating the three holes for the 6W12-1 balance arm. The holes will be in slightly different locations on each attaching rib so it will not be possible to back-to-back match drill them. Image #2 is a simulation of the arm between the ribs at an exaggerated angle. While reviewing the blog of ZAC's 601XL demonstrator upgrade on zenith.aero I noted that the arm appeared to exit the aileron at a right angle to the front web.
Start of End Rib Opeing
Balance Arm Simulation
Cut and Drilled
Cut and Drilled
