Brief Description: Formed New Ribs, Match Drilled 2
Rather than chance having the balance arm attach holes be too close to the tooling holes on the original ribs I took a little time to form four new ones.
After forming I measured, marked and located the two inboard ribs to the skin. The web height on the skin is about 2 to 3 mm too wide so I need to rebend the top flange - if possible - to get a better fit to the ribs. If not I'll have to rebend a new skin: Arghhh!
