Located and marked lines on two ribs for attaching the center channel with standard "L" angles. After attaching the angle I discovered that the 6T3-2 center channel formed back in February was about 2mm too wide to fit the ribs so I bent up a new one that fit perfectly. Locating and clamping were the most time consuming part of this work. Fabricating, cutting and drilling went fast.
