Cleaned end ribs and spacers with Simple Green and 3M pad. Taped over exterior rivet holes along end ribs and rear spar lines. Brushed Rustoleum Clean Metal Primer on all mating surfaces and blind side secondary rivet heads . Will wait to prime hinge until after it is drilled for the elevator.
