Finsihed riveting left fuel pump doubler in place. Installed nutplates and bolted both fuel pumps in place.
L+R tanks - Drilled holes for outboard vent. Installed snap bushing and cut bulkhead fitting for bottom of wing. Cut 1/4' line and bent/flared per instructions. Vents complete.
L tank - Cut/shaped/flared and installed fuel tank oultlet to fuel pump inlet line and fuel pump outlet to forward fitting line.
Flow throgh vent line and electrical connection routing still to be determined.
