Brief Description: Left Aux Tank Install and Fuel Tank Repair
Marked and match drilled bolt holes on forward mounts. Removed tank and deburred holes. Installed nutplates. Match drilled aft doubler and deburred. Installed nutplate.
Match drilled inboard fuel pump doubler and deburred holes.
Enlarged tooling hole in rib for fitting.
Started repairing main fuel tank leaks with proseal.
