Brief Description: Tested Lt Main Tank and More Aux Tank Install
Tested left main fuel tank- again- small leak associated with aft baffle.
Drilled and installed nutplates on four forward mounts. Tightened bolts and clamped aft doubler in place. Match drilled holes for rivets and attach bolt. Riveted doubler in place and riveted nutplate in place.
Completed match drilling fuel pump rib doulber and riveted in place. Enlarged forward tooling hole for fuel line connection.
