Brief Description: Ailerons Complete, Tested Rt Main Tank
Completed double flush riveting of both aileron trailing edges. Installed mounting brackets and attach hardware.
Section 21 Complete!!!
Setup and tested right main fuel tank. Two small leaks- one around fuel level sender and second on outboard upper end of aft baffle. Will check left tank and then repair and retest.
