Steves S-20 Build Site.
Date: 12-29-2018
Number of Hours: 3.00
Brief Description: Misc Tasks - Cont'd.
I have the critical electronic systems protected by circuit breakers mounted to the panel, and for less critical systems, like my music ipod, I used a fuse block behind the panel. I printed out a label to indicate the purpose of the fuses and used packaging tape to fasten in to the radio stack plates near the fuse block.
The early S-20 firewalls came with holes predrilled for the fuel supply line as well as the return line. Since I used a gascolator, I was able to run the return line back the gascolator, and did not need to run it all the way back to the header tank. This left one of the holes open, so I made a circular plate and riveted it place to seal up the firewall.
I also spent some time installing most of the miscellaneous parts I had recently painted including the elevator trim servo cover, the elevator pushrod exits, the nose wheel strut cover, the rudder cable close out, and the flaps handle covers.
Fuses on the left, diagram on right between heater hoses.
Close out plate to seal return line hole in firewall.
Flap handle cover and rudder cable close out.
