Brief Description: Wing Reinforcements and Patches.
Glued all the wing reinforcements and associated patches in place.
* I found there was interference between the aileron hinge exits and the mounting plate for the aileron push rod cover. After test fitting the aileron hinge, I found that I could trim about 1/4" off the legs of the aileron exit, eliminating the issue. EDIT - I later realized that I had not accounted for the nut plate that gets riveted on the aileron hinge. I will have to remove some material from the aileron exit plate to allow installation of the completed hinge assembly. - Not the end of the world, but in hindsight I probabaly would have moved the aileron pushrod exit instead of triming the hinge plate.
