Brief Description: Prepared the wing reinforcements and patches.
I scuffed all the plastic wing reinforcements, modified the aileron hinge exits per the manual, and fabricated a new reinforcement to go around the the temperature sender I mounted in the bottom of the RH wing.
* I used a 3D printer at work to print out a 2" diameter wheel with a small hole in the middle and used that to trace around the plastic reinforcements leaving an outline for properly sized cover patches.
* I started marking out the locations on the wing panels, and will finish and start gluing next time.
