The next step in the covering process is to put the patches and tapes on the wings. To do this I need to access both the top and bottom several times, but turning the wings on the saw horses is a delicate process when alone, or requires a readily available set of extra hands. To make this easier I constructed a set of wing stands that will allow the wings to be rotated. I will use the same stands during the painting process.
* I think I will add a board to connect the two stands together. As it is, they are a little light on the inboard side, and do not cooperate well with each other when being moved.
My jig for drilling holes to hold several positions.
