Steves S-20 Build Site.
Date: 8-19-2015
Number of Hours: 3.00
Brief Description: Teleflex, Flaps, and Trim Tab.
In preparation of getting to the covering stage, I wrapped up a few miscellaneous items including installing the teleflex cable, the rivet nuts in the flap frames, and assemble the trim tab halves.
Comments:
* The only noteworthy item was the breakage of two #30 drill bits while installing the trim tab end ribs. The bit hits the rivet nut and bends until it breaks. After I broke the first one, I was being very careful, and broke the bit on the very next hole.....
* I am getting close to the covering stage. Items left are to mount the magnetometer in the wing, run some wires and pitot lines in the wings, fit up the boot cowl, and assemble the header tank. I need to build a wing rack so I can get the fuselage back on the sawhorses to fit up the boot cowl. I am excited to start covering and making it look like an airplane!
Teleflex cable installed.
Rivet nut plates installed on flap frames.
Trim tab halves. These will be joined after painting.
