Completed the AeroLED Suntail wiring harness. Started by soldering on a pigtail grounding wire for the shield itself. This will connect to the suntail mounting screws, and ground the entire shielding to the airframe. Continued by soldering the 3 conductor shielded wires to the Suntail, and heat shrink the harness to help stablize the wires. Terminated the harness with a Seal-All connector.
Test fit and tested on the aircraft. Successful.
Installed nutplates on the vertical stablizer for the fiberglass fairing.
