Completed the trim switch wiring from the VP-X Pro and the Pilot's control stick. Tested circuit via the china hat and configured the Dynon Skyview display for the pitch trim. Completed the wire runs for the roll trim, although I have not decided if I will use electric or manual trim for the roll component. Van's has both depending on how much you want to spend... Completed the run for the OAT probe, Mounted the probe in the very aft section of the aircraft. Pinned out to the ADHARS unit and tested. I will need to shorten the wire a few feet.
One wire at a time... getting closer everyday.
Note: PS Engineering has shipped my Audio Panel wiring harness, should have it on Monday.
