More Baffle work... I completed the final fitting of the air inlets... Turned out nice. as you can see all the finger prints on the cowling... it came on and off many times. I need to get things riveted up, and install the baffle material, and of course the cosmetic work.
I plan on doing the intial engine run-in on the plane. One of the local engine builders has a induction shroud I can use... It is like a big air-scoop to increase cooling air flow during the intial ground runs.
