My RV-10
Date:  11-13-2012
Number of Hours:  1.50
Manual Reference:  EMAG Maint. Man.
Brief Description:  Plug Wires / Switch Panel
Cut the access through the baffles for the plug wires.
Installed the pass thru and bolted in place.
Installed the spark plugs.
Terminated the wires for the left EMAG-P to the switched panel / grounding block.
Installed the vacuum line.
Powered the system up, and timed the mag per EMAG Manual.
Everything worked as planned.
I still need to secure the plug wires as I did on the left side
I know things look a little rough, but they usually do at this stage...
Switch layout is as described:
Red: Master
Upper Right: Switch for ALT 1 (Up) and ALT 2 (Down)
Yellow: 12v to EMAGs Left / Right
White: P-Leads to EMAGs Left / Right
Lower left: Avionics Master
Lower Right: Pilot Heat
I have not decide where I will install the Starter switch yet...
Possibly, Centered below the Avionics / Pitot Switches?
Maybe on the stick?
The VP-X Pro disables the starter when it senses 600rpm, so the stick is an option...
We will see...
Plug Wire Routing
Plug Wire Routing
Left Side Secure Example
Switch Panel Layout
Switch Panel Layout
