Bought a strap wrench at Home Depot... can you believe it was only $5? Anyway I lightly cushion clamped the EMAG to my bench to steady it. Installed the drive gear along with the woodruff key, held the gear with the strap wrench and torqued the nut to 140 in lbs, then installed the cotterpin. Installed the EMAG on the engine temporarily.
