Continued work on the engine baffles... I started the baffle section for cylinder #3 to jump ahead... see below:
They fail to mention if you plan on mounting oil cooler in the aft baffle behind #4 cylinder you will need an additional kit from Van's. I looked online and it is $180 bucks. Maybe I missed this, but I don't remember reading about this requirement or I would have ordered it at the same time as the baffle kit.
Anyway... I do plan on mounting the oil cooler on the baffle... so it is time to order.
