Installed / Torgued the governor plate. Installed / Torqued the oil sump. Installed / Torqued the intake pipes.
It is starting to look like an actual engine, instead of a rack full of parts. Hope to have the other two cylinders by Sun n Fun... As you can see... I need a fuel pump, carb, starter, and some mags.
I will core trade my fuel pump. Possibly rebuild my carb... or core trade. Probably will go with a SkyTec starter. I will go with (2) P-Emags. I also plan to go with a Plane Power 30a backup alternator.
