My RV-10
Date:  12-18-2011
Number of Hours:  1.50
Manual Reference:  Lyc. Maint. Manual
Brief Description:  Crank / Rods / Case
Basically ran over to the tool shop to get my torque wrench checked out.
I am lucky that there are other folks like me, work all the time. Anyway the torque wrench was right on, with a 1/4 ft lb... at 25 to 75 ft lbs range.
I went to work on the connecting rods... torqued to 480 in. lbs. (40 ft. lbs)
per Lycoming pg 7-14 Sec 7-68/69 - Torque Limits Table 1-37 Ref 900 Type S
Checked side clearances at .008-.010... Table of Limits 1-2 Ref 502, within new limits.
Then I installed the required plugs in the case... Cleaned, inspected oil passages.
Applied sealant to plug threads and torqued to 40 in. lbs. Per Lycoming Torgue Table II Pg. 1-37.
Rods are Torqued
Rods are Torqued
Side Clearance is Fine
Plugs are Installed
Plugs are Installed
