Installed "NEW" Oil Filter Adapter, gasket, sealed and torqued. Installed "NEW" one piece Oil Pump Housing, impeller gears and Shaft. (P/N 05K19423-S) Pre-lubed, Torgued to 150 in lbs, and safety wired in accordance with the following.
References:
Lycoming Direct Drive Overhaul Manual 60294-7 - Revision June 2002 7-10B Service Instruction No. 1164B Service Bulletin No. 524 FAA-H-8083-30 5-80
