My RV-10
Date: 7-16-2012
Number of Hours: 6.50
Manual Reference: Sec 9 DWG 41/43/44
Brief Description: Canopy
Installed the Roll Bar... Wd-641 Made sure everything was measured, squared and clamped in place. Fitted the C-668 spacers, drilled per DWG 42. Bolted everything in place, it took forever to get the spacers, bolts, washers, and nuts in place. To get under the F-721B flange was a pain in backside. I check for square, looked good. I installed the forward fuselage structure and top skin. Fitted the Wd-643-SS roll bar brace, drilled and trimmed to F-7108A/B. Cut to length to the Wd-641 roll bar. Removed the top skin, and bolted everything in place.
Assembled the Wd-644/C-658 roller assembly. Cut the C-657 canopy tracks, layed out and pre-drilled the channels. Clamped the channels in place and rolled the slider frame in place. Drilled the C-661 rear slider block... that's where I screwed up. I will need to buy another one $11.40... per Van's web store.
Other than that... it is going to together pretty good.
Roll Bar
Roll bar brace
Slider Frame
