My RV-10
Date:  4-18-2012
Manual Reference:  Sec 8 DWG 33
Brief Description:  Flap Actuator
Drilled the flap actuator clevis to 1/4"
Drilled the F-680 bearing block and cut to size and in half.
Fitted the flap actuator control in the fuselage.
Postioned the F-680 bearing block, checked clearances and clamped in place.
Check actuator travel.
Flap Actuator
Flap Actuator
