Finished match drilling the forward bottom skin to the firwall. Drilled the rudder pedal mounting blocks F-6116. Measured the 3" from the firewall along the F-719 aux longerons. Removed the F-719's and fitted the F-6116 blocks, and drilled the first set of mounting holes. Measured 1-1/8" center to center... and I now have 6 holes. and 3 adjustment settings. I am 6 ft tall, so I will probably have them adjusted to the middle position as pictured.
Mounted everything into the forward fuselage just to make sure everything lined up.
