Worked on the Rudder / Brake assembly today. Used some scrap 1" angle to secure and align the rudder pedals. Also secured the brake pedals from behind to make sure they were perfectly aligned. Then dug around the tool box and found a sacrificial 3/16" dtill bit, cut it to about 1" in length. Sharpened the end, and used it to lightly scribe the hole placement. Measured to locate the center, drilled and deburred the hole.
Check operation... for both Left and right side brake system.
