My RV-10
Date:  6-7-2011
Manual Reference:  Sec 8 DWG 26
Brief Description:  F-706 Bulkhead
I began to work on the F-706 bulkhead.
Sorted and fitted the parts.
Fabricated the F-729C angle.
When it came to the F-729B angle, calling for .063 3/4 x 3/4... the angle is over 25 inches.
I looked around the part bins, and all I could find that would fit the plans was...
I found two .063 3/4 x 3/4 angle stock, but each piece was 12 feet long.
Before I cut anything I need to make sure this is the correct stock to use.
I looked over the plans and did not see where this stock in used for any longerons.
I emailed Van's referencing the plans and parts just to make sure I am not missing anything.
I do not want to cut these pieces until I hear from them... I am sure it would cost a ton to ship these pieces if I make a mistake.
