Continued to work on the aft bulkhead. Fitted / Match drilled the seatbelt mounting brackets. Fitted / Match drilled the remaining bottom supports, after buying a new bandsaw blade, really made the job go fast, cut it easily and straight. Waited way too long to replace the blade. Fabricated the seat adjustment angles / match drilled.
