My RV-10
Date:  5-28-2011
Number of Hours:  3.00
Manual Reference:  SEC 8 DWG 11
Brief Description:  Fitted Center Spar Bulkheads
Made the temporary spacers.
Fabricated the aluminum tubing spacers.
Fitted / mated the two bulkheads with the spacers.
The process was not all that easy, the bolts are such a close tolerance fit, it takes a bit to get everything in place. After some gentle tapping the bolts fit perfectly.
I torqued the required bolts on a few of the flanges and followed up with torque seal.
I also took delivery of a replacement governor Gear / Housing for my engine.
Governor Gear / Housing
